Hey im looking to uninstall the turbo timer that came with my 180sx
has anyone out there done this???
or maybe if you’ve installed one do you know how to uninstall??
please help!! :wall:
there will be a harness for it that plugs into your ignition harness under your steering column. Unless it is hard wired then yo ucan just unplug that harness and one black ground wire that is separate and it should come out
ok perfect thanks!!
its a razo turbo timer, if that makes a difference; ill take a look at the wiring tomorrow and see.
does anybody know how to wire the turbo timer into the e brake?
The wire should be t-ed of of the small wire that goes to the e-brake. It’s the wire that sensors the e-brake is up. Just take off the middle console (a few bolts and screws) and you should locate the where the wire parallels off to the turbo timer.
It is very effective when it is wired off the ebrake actually. I like starting my car and having it warm up with the turbo timer running it rather than a key. Having the OEM column lock as well as the ebrake wire setup there is not many ways someone can drive off with it.
