so i was tryin to wire the 6.5’s in my s13 hatch, it came with the factory active speaker system, i took the old shits out and theres a plug with 5 oem wires, do i have to bypass the fac. amps? or which oem wires go to the back of the 6.5s ?
i did,
are you using a new head unit?
i believe the blue wire with the white is for the amp, which color wires should i connect for sound anyoneee?
bump
anyone ?, it sucks listening to 4x6’s
If you’ve replaced your head unit, just run new wires directly to your speakers. If you don’t want to do that, a multi-meter should help you eliminate your choices.
You made a thread already and I told you exactly what to do, but I guess its too much effort to look in the FSM or run new wires.
Looks like your stuck listening to stock speakers unless someone decides to spoon feed you the answer.
