Hub-Centric Rings/Lugs
Anyone know of a local store that sells either of these items? Trying to see if it’s cheaper to pick them up locally instead of buying them online.
I got a cheap plastic set local but they had to be ordered. The ones I found online seemed kind of expensive. It’s not even close to you though - Marsh Tire in Charleroi.
How much were they charging?
I don’t have a receipt for them, but I want to say under $20.
This was the brand they got for me:
http://www.tradeunion.com/toplineproducts/subs/hubcentric.html
Marsh’s number is 724-483-8861
that rim shop in Mckeesport sells them.
States Tire on Lysle Blvd?
yeah thats it
I found rings online for $15 shipped, so I’m ordering them tomorrow. Now I just need to figure out which lug nuts to buy.
Was double-checking everything before I ordered and the hub rings I found have an outer bore of 72.60mm and the rims they are going to have a bore of 72.62mm. Does anyone know if that .02mm is going to make a difference/cause a problem??
No it definately will not. Don’t even sweat it.
