Are bearings from front hubs in s13 and s14 interchangeable?
In S13’s they are, not sure about S14 tho.
So I should have no problem using S14 front hubs bearings in my S13 front hubs. Right?
Different.
Can’t use them unless you switch to s14 spindles.
EDIT : rears are interchangeable if I remember correctly
yepp S13 uses a 30mm bolt, while S14 uses 32mm bolt.
ooppps sorry i thought you meant interchangable as in replaceable.
What about 5bolt s14 and 4bolt s14 bearings, are they the same?
Anybody? I need front bearings for s14. Please!
