Posting pricing since i’ve had a couple Genesis guys reach out recently.
ISIS Suspension arm packages.
Rear Upper Arms
Rear Toe Rods
Rear Camber Arms
Front Tension Rods
Front Lower Control Arm
Rear Lower Rods
$180 CDN each + shipping
if you get the whole set take $10 off per pair.
Exhausts: for 2.0T version only (same with downpipe)
Race:
715 CDN + shipping
Street:
$755 cdn + shipping
Short Shifter:
$170 CDN
Aluminum Radiator:
2009+ Hyundai Genesis Coupe 2.0T. This is a great upgrade to your stock radiator. Turbo setups produces a large amount of heat and by replacing your current factory radiator with the line ISIS performance aluminum radiator you will notice a cooler more efficient engine. This application is designed as a direct OEM fit with no modification required for easy installation.
$270 CDN
hose kits available in blue, red and black for $80
ISIS downpipe with flex: $230
link: LINK
image link doesnt work for the downpipe so just sharing the Enjuku link instead.
Test Pipe: $120
O2 housing (turbo elbow): $220 / $230 (2013 - V2)
2013 V2
