Talk about letting your brakes go…
Uh… is that real?
Not to bad, probably enough there to get them turned down once more.
What the…
Holy shit. Thats some serious neglect right there! dayummmmn
What in sega genesis? :o
LOL
i call BS
that doesnt make any sense…not saying its fake, but i dont get how this could have happened…
:Idiots
seen that happen on a jeep but not quite that bad.
why is hte bottom part of the rotor cut?
It appears to be cracked, which I would expect under these conditions.
Since the periphery of the disc is moving master than the ID more work is being accomplished and more heat will be generated.
Since the outer pad appears to have a significant amount of friction material remaining, and yet the piston side pad is obliterated, I would speculate the the sliding pins have seized causing non-uniform wear of the pads.
You can see near the hub where there is a raised burr on the outer side, which indicates that the rotor was divided from the inside of the car to the outside. Most likely by the backer, or the piston itself.
:thumbup
curiously the rotor on the opposite side looks decent…
:crazy
I heard these are clear lexan brake rotors to go with the clear lexan wheels.
Driver was a female
/Thread
I have actually seen that happen before. its absolutly CRAZY to see in person.
it was a 94 Integra. ended up needing a new caliper, and obviously pads and rotors.
other side was almost as bad. it was seriously thin as paper
btw sweet Side exit Exhaust on that car!
heyyyyyyy wait a sec! i take care of all my route up keep on my car!!! not fair :Idiots
thats nuts…
oh my ass:facepalm every fucking time!!..you gotta understand this…he didn’t say ohh it mut have been amanda, no. he said female driver…so stop taking offense to everything people say…
LOL!!! good one!
