i got to questions for s14
1st
whats a good way to put the gauge pod holder on the pillar like the best way to hold it in place?? what did u guys do ???
2nd
does anyone know how to change resistors in the heating cooling unit…
power 1 doesnt work power 2 doesnt work power 3 doesnt work but power 4 works
i no that this is the resistors b/c same thing happened to my altima.
does anyone know how to change and how much are parts
thanx for your time ciao
What exactly is wrong with the resistors? Did you check resistance to see whether they are fucked? If they are garbage you will read infinite resistance, open circuit.
Blah blah blah. Blah!
Edited by Mod. ON
YOU DONT NEED TO TYPE IN ALL CAPS.
Please type normally.
sorry about that i get carried away sometimes
i said power 1 power 2 power 3 doesnt work power 4 works i no its my resistors b/c it happened to my altima. ( dads car) same year and everything. . does anyone know how to change it??
and how do u put the gauge pod on the pillar?? acutally whats the best way to put it on. .
Is it a single or a double gauge pod?
I had the same problem with the resistor, its failry common…the part cost about $35 from nissan. It’s just behind you’re glove box, and it unplugs like a memory card. From the bottom its a black plastic plug a little bigger than a credit card. I took my glove box right out while I was doing it, but I don’t think you’d have to, just take a look under at the back, its held on by 2 screws I think. Pretty quick/easy thing to do… Gimmie a PM shout if you need more help.
James
single gauge pod
and thanx DePhrag for the help/tip!!
Is it the Autogauge pod?
yes it is
dont tell me theres no one on this site that doesnt have it on the pillar!!!
i used the friction pins that are supplied but i drilled the holes one size smaller. i had no problems with mine and it’s heavier being it’s a double gauge pod.
