I need help from someone in mississauga!!
hey,
ok after like 4 or 5 weeks now, car still isnt running…we cant figure it out and they would like to compare engine bays with someone who has a '91 + s13 or someone with '95 s14! theres tons of plugs and thing that dont match up anywhere…this is honestly turning into a nightmare! if someone is located in misssauga or near by and can help me with this, ill pay for gas, but id need help tpday if possible!
pm me if u can or add me to msn… jerryswrld@hotmail.com
thanks!
was this an auto car? have you searched for auto->manual swap
as I said earlier it is easiest to use your S13 intake/exhuast manifolds, ECU/MAFS, distributor, and S13 engine harness (DOHC)
EDIT: you are also going SOHC->DOHC?
i have read the auto to man. swap . no issues there The car was a man. but the engine was auto…
I am goin soh to dohc
i have a '93 harness, maf, ecu, disstributor, and exhaust manifold.
The only think i havent swaped is the upper and lower intake mani. because people say the only reason to swap it for the EGR system, so i left it.
the car runs and idles fine, but as soon as you plug the maf in, it dies or only runs with gas…
there s a few plugs here and there that we cant figure out where they go and for some reason on my harness there is no TPS plug anywhere to be found and the harness was not cut. I looked at a buddies altima which is a '96, and he also has no TPS plug, so i figured its ok.
someone give me a call on my cell if u can come down…id really appreciate the help, and ill pay u for gas! 416.889.6904 . --> jerry
im going to the shop to figure this shit out…
thanks!
