I have a 12V DC motor that I would like to reduce the voltage to. Instead of getting the 12V or 13.7V (when car is running) I want to be able to reduce it to 5-6V. Maybe even make it so I can adjust it with a knob.
I’ve thought of using resistors but, the motor pulls too much current and would beat them resisitors up FAST.
Voltage = 12.4V car not running/13.7V Car is running.
Current = 3-5A~? Im not 100% But, it says in the instructions to use a 6amp fuse. I guess I could check that today.
Its for the electric water pump for my IC on my car. I bought a pump that flows too fast :oops:
My options are to either buy a lower flow motor, or to make an adjustable voltage regulator. I think building the the regulator would be more fun. I have my prototype breadboard sitting here and trying different circuits using transistors, voltage reg, a 10k pot. But, need to figure out a circuit for higher current. THe reason I’d like it adjustable is, I plan on running a big resv. and might end up needing that extra flow.
Just need the primary transistor (3906??) to be able to handle the current (Make sure to put a heatsink on it!!!) otherwise it’s the same circuits as the low-power motor speed controllers.
The slower the pump goes, the less the water/methanol etc. will atomize when it comes out of the nozzle. It will probably make things worse. What you need to do is get nozzles with a finer spray pattern. Also, did you get a high-flow pump or a high-pressure pump? You need a high-pressure for this application otherwise a finer spray nozzle will still dribble.
I agree with Brians suggestion. A PWM circuit is the cleanest, and most efficient way to accomplish what you want. Spec it for 50% over running current. Maybe 7amps? Check tho.
Yup, no spray just water pumping. Since I’ve only ran water through the pump, I might try to be chummy with the people at the place I got the pump, see if they’d let me trplace it with a lower flow. If I had a few more bucks, I’d one of the many OEM pumps for…Cobalt SS, 'stang GT’s, Sy/Ty, ect
