Identify Part I Need!
see the hole in the rotor that isn’t filled for anything? It’s the hole thats for adjusting the adjuster screw for the drum shoe e-brake assembly. I need the screw that covers that hole so water doesn’t get at my e-brake assembly.
Possibly under Maxima category, but these are 300ZX rotors.
I just need the part name/# so I can get it from Nissan stealership.
Thanks guys.
You can ask the parts guy to show you a diagram, and point to it. You don’t need part numbers as long as its not a jdm part.
put piece of tape over, bam no more water!
It’s a rubber plug.
Tape on a rotor that can get glowing hot, not such a good idea. Unless its Aluminum tape.
yeah its just a rubber plug, pretty sure you can take one from any nissan rear brake
this hole is for access for adjusting the parking brake in 300zx/r32 ect, its best u cover it up with the right plug, there like $5 from nissan
^^ yeah I know what the hole is for and that I need to plug it up and I need to get from nissan I just dunno what it’s called LOL
Chewing gum.
