350z help
My ebrake dosn’t work!
I tightened it but it still won’t grab at all?
Pistons arn’t seized and pads are new.
Ideas?
cable is probably stretched
350z is drum style no? your pads and pistons shouldnt have anything to do with it.
Talk to sasha (sgmotorsports)
im pretty sure it has a parking shoe, your rear rotor sits over them they need to be adjusted.
---------- Post added at 04:02 PM ---------- Previous post was at 03:52 PM ----------
take off the wheel, there is hole in the rotor that should have a rubber plug in it.
then take out the plug and line it up with the adjuster and adjust, all you need is a screwdriver to adjust the shoes.
Thanks Rex, Worked perfectly!
