I swear, I must really suck or this is just a bitch, but I can’t install the
pads on the rear brakes.
Those fuckin retrainers just wont stay and I dunno if I’m doing it wrong
or what, but I just can’t do it. I spent like 3hrs in the garage trying to
install the pads on the driver side and its still not done.
Anyone wanna come by Fri. evening or Sat. morning and give me a hand?
first of all turn the piston clockwise and seat it entirely
then pull the pads out obviously
then remount the retainers in there, the little 90 degree things that look almost like teeth sit on the inside of the caliper and the metal sliding part fits inbetween the caliper
put the pad loosely in the caliper
hold the metal shims in with your index fingers at the back of the caliper (towards the piston) and hold them out all the way
using your thums press the tabs of the brake pad into the caliper and it should slide right in you need to get it dead on or it wont slide in.
alternatively you could have used a large C-clamp. Put the ball end of the clamp in the brake piston and turn the clamp till the brake is fully compressed.
Compressing the front pistons is perfectly fine. The rears should be rotated down clockwise because of the e-brake setup. You might need to apply some pressure while rotating. If its really pesky take off the caliper put it in a shop vice and use a nice big pair of pliers to screw the piston back down with a bit of force. As for whether or not you damaged your brakes I think you should be okay. Just make sure to test them and the e-brake before driving. (and bleed the system if you removed the caliper)
soo your piston can turn but not go in?
if it’s sticking very out and turning and not going in, then you might have poped the piston out, --> nneed a caliper overhaul
use a small plyer to turn it and push the plyer in it while turning…
I only had to hammer it in maybe a few mm. I dunno what kind of
force is required while turning it so after getting impaitent, I just tapped
at it with a hammer.
So well the good news is I got the pads seated in the retainer good.
But now the god damn rotors won’t fit. Seems like the pads are a few mm
too thick or some shit.
I got some generic pads from Napa (box reads 94 240sx ; I have a 92).
I checked the FSMs; all generations of 240sx have the same rear rotor
and pad size/configuration.
Perhaps I need to shave the pads down a few? It’s the pad that’s on the
outside (the one touching the front face of the rotor).
Welp, found the problem (thanks to Paul aka Axlerod).
Turns out that one of the slider pins is seized. Hence the uneven wear on
the pads that came out of that caliper.
I tried hammering it, turning it with vice grips and its not moving one bit.
So as a last resort, I used the pad from the other side that still had good
meat left and even wear. With this pad the rotor fit.
Not only that, but that same caliper wouldn’t retract in even while turning
it clockwise. The other side, however did retract in upon turning and its
sliders were still good.
But I’ll definitely need to replace this caliper soon seeing it won’t last
long (I commute about 400-500km/week for work :noes: )
And after I had figured out how to put the pads in the caliper, it took me
maybe 30min tops to do the other side. Now I’m an expert. :wiggle:
Pic #1 - Bad caliper with old pad in the front
Pic #2 - Bad caliper with new pad and rotor for comparison
Pic #3 - Good caliper with new pads
Pic #4 - Bad caliper with new pads
