My '97 240sx SE is driving me up the wall these days. It is showroom stock, and has 97,000 miles on it.
For the past two months, it has had intermittent starting problems. When I turn the key to the “start” position, sometimes I will get one click from the starter. After turning the key a second time, the starter will engage and the car will start normally. Sometimes it gives me a problem, but most of the time it doesn’t.
The problem has gotten worse in the past two weeks. There have been a few occasions where it takes a good minute or so to finally get the car to start. It happens regardless if the engine is hot or cold.
Last Friday, the problem got bad. I got no response whatsoever when I turned the car to “start”. I had the car towed to the dealer, and they unhooked my alarm system, saying that the starter-kill feature was preventing the car from starting. They also said that the starter was fine. Fine. Well, this afternoon it happened again! After turning the key a few times, it finally started.
So here’s my question…
Call me crazy, but I think it’s the starter (anyone else?) The battery was replaced last week, so we can rule that out. Can it be anything else other than the starter? How about the ignition switch? Reason I ask is because I bought the car with a P.O.S. alarm installed, and it had an “electronic key” so to speak, which you had to plug into a module in order to start the car along with your standard key. Well, the “electronic key” was never provided, but you could get around it by turning the ignition from “ON” to “Start” 4 times and then the car would start. Could it be a bad ignition switch from all of the wear and tear (in essence, it would have 4 times the wear of a normal switch), the starter, or something totally different?
I’m losing my mind, and am moving from Florida to Toronto next month…I’m terrified that the problem will happen again somewhere in between. Most likely in some hick town, hundreds of miles away from civilization. LOL… That would suck!
Please help…I’m desperate for any input on this. Thanks in advance.
Jason
