ka-t parts
if anyone has anything i need, pm me.
any ka-t parts to run a turbo set-up. if i can put everything together cheap enough i may go this route instead of a jdm swap.
regards,
matt
well then you might want to tell us what it is that you need…
Didn’t you read Cal?? he clearly stated anything!
selling my turbo for 430new low price. must be sold in 3days (befor ebay aution is done.
can also sell you an external WG with a 14psi spring and a 6psi spring for 160
(590)
mani - bings.ca 300?
downpipe - 100 and a muffler shop
injectors 370cc -100 ebay
oil lines - 100 cisco mississauga
(600)
You can use on a sr or you will need to get:
SAFA - 200ebay
FMIC - bings.ca 300
IC pipes - i used ABS pulming pipe for a long time 50
walbro fuel pump - I saw them on here for 100
blow off valve - 50 for a dsm on ebay.
boost gauge - 50 autometer
(750)
everyting, the whole thing. starting from scratch.
thanks justin,
helped a lot,
regards
there might be a few more things like oil pressure gauge (good thing to have)
cold spark pugs and other small things.
oh and a bigger exhaust but you will need it with a sr20 as well.
