This is mostly for the Honda/Acura crowd, but if you have any questions about making a custom wiring harness, hiding wires, running -AN lines, Wiggins lines, whatever, ask me. If I don’t know the answer off the top of my head I can probably find it for you. Below is some useful information…
First and foremost, I will be offering wire tucking services for a fee. More information will be available to those who inquire.
Army/Navy (AN) fittings information
AN fittings are all 37 degree flares. NOT 45 like SAE fittings. You will have leaks if you use a regular flare tool when installing AN fittings.
Summit 37 degree flare tool (SUM-900311)
To convert from AN to SAE is simple. Say you have a 5/16’s fuel line. This means your fuel line is -5AN. If your fuel line was 1/2 it would be -8AN and so on and so forth.
To convert from hardline to stainless steel braided line you need a few things.
- A tube nut and tube sleeve that is the same size as your hardline
- An AN adapter to convert the tube nut and tube sleeve to AN size and thread
- An AN fitting to go to the hose.
Below is a list of fittings and lines needed to do a custom fuel feed line on a Honda or Acura. All part numbers are from Summit Racing.
After the stock fuel line is cut and the stock fuel filter is removed, put on the following fittings in order
Earl’s -5AN tube nut (EAR-581805ERL)
Earl’s -5AN tube sleeve (EAR-581905ERL)
Once the tube nut and adapter are on, flare the line, then attach
Earl’s -6AN to -5AN reducer (EAR-991907ERL)
There are a lot of choices for hose ends. I suggest Summit -6AN straight hose ends (SUM-220690)*
Stainless hose (SUM-230603) for 3 feet or (SUM-230606) for 6 feet
Another straight hose end (step 4)
Inline fuel filter of your choice. Be sure to pick -6AN male on both sides and 40 Microns or less (Go to Summitracing.com>departments>air and fuel delivery>fuel filters)
90 degree female coupler (EAR-935106ERL)
An adapter from the coupler to your fuel rail (EAR-991945ERL) This is usually the fitting for an OEM fuel rail. If you have an aftermarket rail, then get a -6AN to (insert your thread pitch here) adapter
*add b to the end of the part number for black anodizing or n for nickel
This is the easiest way of going about a stainless hardline with an inline filter. If you want to get creative, then do it. I’m not going by this exact set-up either ;D
I will update as more questions are asked
