Why are you pulling the heads out the bottom? Quattro Krant has done 3 or 4 sets in my garage and he’s half bat-shit retarded and I remember helping pull them out the top.
come see my place anytime broski.
You’re welcome to check out my lift anytime if you want a feel for layout and dimensions.
Easy… Mark a spot and cut with Demo-SAW
[ATTACH=CONFIG]31754[/ATTACH]
Getting the first one up and out is a cock
[ATTACH=CONFIG]31755[/ATTACH]
Rest aren’t bad.
[ATTACH=CONFIG]31756[/ATTACH]
Clean out the hole
[ATTACH=CONFIG]31757[/ATTACH]
Cross drill, and insert rebar with epoxy in a grid pattern, wire, add mesh, add 8" of High PSI Crete on top of tamped gravel.
[ATTACH=CONFIG]31758[/ATTACH]
Get lift bolted down after waiting for crete to dry.
[ATTACH=CONFIG]31759[/ATTACH]
Get custom high lift track doors put in
[ATTACH=CONFIG]31760[/ATTACH]
Sub panel Brah, 250’ of 12/2, outlets everywhere brah, 220 in the ceiling for the lift to plug into brah, Dimmers and fans brah, switch outlets, and madness all set for jackshaft openers and craziness!! I really did over-wire the living shit out of the place. New owners are going to think I’m a loonytoon, or a genious… fine line brah.
[ATTACH=CONFIG]31761[/ATTACH]
Compressor Brah
[ATTACH=CONFIG]31762[/ATTACH]
Ditched the tire equipment because they’re a pita and I don’t use them enough. Thinking of ditching the commercial volume air dryer capable of supporting three times what my compressor can since I won’t EVER paint, but I’ll be putting in a ton of copper and drops this summer and putting the compressor in the back garage (I love you out-building!!) and running a remote three-way switch and plumbing underground so I might keep it.
I can pick up a half ton full sized truck but it’s a rotten bitch with no room. My Ridgeline I can lift up all the way inside with the door open or closed and walk around it and pull tires/change oil.
Rest of my pics I can’t really post due to content since I’m not a sack rider craving attention whore.
Oh yeah #dickpic just for grins.
because I’m a stubborn fuck and refuse to pull the intake mani…
reading all your posts now
I’ll have to come out and see both your places in person when it’s warmer. Maybe the 2 post isn’t impossible. It’d be really nice to have a rep (or someone who has experience cramming lifts into small places) come out and take a look at my setup to see if they have any ideas I haven’t come across yet.
fuck, i would kill for a couple extra inches (TWSS)
I am at 220" clear width now
Well fuck the DECA plan for now…$1,400 DDU (Whatever the fuck that is) cost on top of purchasing. That doesn’t even include tax. I don’t care to invest the time reinventing how to import it into the states right now. Unless…anyone has suggestions.
Dead in the water for now my friend.
I was never really all warm and fuzzy importing something from China so no harm done.
To be honest the most realistic options for me are:
-buy a 2 post like this: http://www.gregsmithequipment.com/Atlas-BP8000
Pros: cheap to buy and install, unrestricted access under the car when working
Cons: trip over it because it takes up the space between cars. all the time.
or
-buy this or equivalent http://www.gregsmithequipment.com/Atlas-SLP-7K-Full-Rise-Scissor-Lift
Pros: work comfortably on the car, invisible when not in use
Cons: expensive to buy, expensive to bust up concrete and pour new forms to recess it
I really just stop bitching out the options out there and save up my pennies for option 2 as it’s what I really want/need.
FYI, Option 2 is NOT a recessed ramp. It sits 4 inches on top the pad. Unless you modify it to sit flush. Is that still desirable?
well yeah, i’d have to cut a portion out and repour a recessed slab. that’s why the “con” of price sucks.
yeah…this. I’m finding it cramped even without a lift at all in there.
Can anyone recommend a contractor that could provide a quote on extending the garage width wise? If it helps, the bay where the addition would go already has a slab poured as an extension of the driveway.
Give me a call / text @ 954-3360. I’m with Kaz Brother’s construction now. Thanks.
