Looking for insight. v. Home AV set up.
I am building a new house, (I will have a DIY thread when I have some more time) I am mounting the TV above the fire place, (I havent bought this TV yet, It will be 47"+) and would like some insight on the following:
Where do people place thier componets? (I have no room next to the fireplace, and want to keep them hidden.)
Has anyone placed them in the basement and used IR repeters?
Any insight would be great, It will help me think of my options on my trips back and forth to ohio…
also i havent made any purchases yet so i dont have to use anything “old”
take a look at the photo forums…
its all up to your personal preference.
My dad uses an IR device that is placed under the TV, it has a wire that actually attaches to the front of each device that you want the remotes to reach. Just passes the signal through to the wire and out the other end right onto the sensor. The only downside is that you cannot see what the devices are doing when you hit the buttons.
With a universal logitech remote, it is an awesome setup.
thanks, that is alot of information.
I will look into that.
exactly what I was going to say… there’s TONS of info on there, from dirt cheap to million dollar setups.
there are a million options… you can go a pretty good distance with HDMI for cheap so you can place all the other items in the next room over, the basement below, pretty much anywhere and then control via an IR device like mentioned above.
If you want speakers all around the room make sure you prewire the wall when the house is getting built.
your wallet and imagination are the only limits.
The IR repeaters work well.
I come across them all the time. Many people will use a closet off their AV room to hide the components as well. Personally I’d probably put them in the basement though. Ventilation in a closet isn’t always that good.
^^^^^I’m pretty sure EvoMR did that at his house.
Over the fireplace might be on the high side depending on how tall the fireplace is. You don’t want to be looking up when sitting down.
X…
Here is a cut for the wire, it is 16 GA, overall shield. The one to look at is the 8719. I do not have much knowledge of capacitance, but being an engineer you may so I cut the page that included it in the specs.
My price is 425.77 /M or ~.43 /ft.
http://nyspeed.com/forums/attachment.php?attachmentid=7367&d=1231436751
thanks mike, is this in stock?
Yeah I have a couple thousand feet. I will check to see if I have any overages back there… maybe I can just give it to you.
they sell special lower fireplaces for people who want to do this… If you do it with a full height fireplace it’s dumb because you have to look up.
I’d go 12 AWG if I were building from scratch.
12 GA for your rear speakers… A little overkill don’t you think?
:engineer:
It’s not overkill, it’s a higher factor of safety. :tup:
That all depends on what your going for in the long run. When i built my front channels and subwoofer, i used 12GA inside the cabinets, as well as the runs to the speakers. Personally i wouldn’t go with anything less than 12GA but that’s just how i’ve grown up. and i laugh at the whole “home theatre in a box” b/c they really don’t compare to a well built system.
^ and I was hoping for an equation like newman would have posted to justify why it is better. I am sure that I could work out all of the numbers, but I would have to look up functions and it would be harder for me than you. :salesman:
Naw I’m in business school now.
…16 gauge would have plenty of ampacity for most applications. But if you’re building fresh why not spend an extra $20 or whatever to have plenty of overhead for future crazyness? You’ll get roughly double the safe current capacity. Around 15 amps or so vs 30 amps.
so, FRY, the AC wiring will be smaller then my speaker wire… The longest “run” might me 60’, i will have to pull up the drawings…
When you put your components in the basement, where do you put the DVD/Blu-Ray player/Gaming systems?
Do you have to run to the basement to put a DVD in?
XBox 360 = not possible?
