classic
I got some Lincoln logs and a couple Lego’s if you need help.
i heard if you weld the main caps on its strong than bolts or studs.
This is true, and since the caps are steel, and the block aluminum the bimetallic weld is unbreakable. Good tip, heard that one originated in nascar.
'ol trick I learned from Mr. Yunick.
turn left turn left keep turning left, now go straight go straight
