LSD oil change?
Has anyone done it without removing the diff from the car?
yes. why would you do that? just drain it then get a fluid pump from ct and filler back up. or are you talking about the viscous fluid stuff?
you use 80w-90 in an LSD (according to nissan)
I jacked the car up but discovered that I don’t have room to remove the fill plug (the drain plug is easy)
My ratchet can’t get anywhere near it without hitting something before…
I guess I’ll have to get something with a 1/4 end that isn’t ratcheted and also has a long connector or something, there is no way the one i have will fit.
Did you use a ratchet? did you use an extensions etc?
we did mine when it was out…
just drop that bitch…
it isnt that hard, just time consuming, and can be akward if you are in your driveway.
