I’ve got a bunch of stuff for sale that I won’t be needing any more.
All GM parts are off a 2004 GTO with 40k miles.
241 Heads - Milled .005", 5 angle valve job. Will install stock springs, retainers, locks. $100
Stock Maf - from 2004 GTO. $45
MagnaVolt - fuel pump voltage booster. Used one year, have new install kit for it as well. $90
Alcohol Injection Pump - 0-250 psi, less than a year old. This is the exact pump. http://www.alcoholinjectionsystems.com/p116/AIS-250-PSI-Water-Methanol-Injection-Pump/product_info.html $60
T4 .81 F1 Trim housing - Turbonetics, don’t need it. $130
Tial 38mm Wastegate - new in box, 2 bolt flange. $190 (I have the weld flanges and tubing we can work in if you’re interested)
