Hi, my names mike. One of my friends whos on shift told me to start one so here it is. I have a 92 civic hatchback. Makes 461 whp at 19psi.
Heres a list of some of the goodies in it,
81.5mm Arias Pistons, Eagle Rods, GSR Crank, ACL Bearings, GSR Transmission.
Type R Oil Pump
Type R Water Pump
Moroso Oil Pan and Battery Box
ERL Blockguard
Type R Valves, Springs, and Retainers
Type R Intake Cam CTR Exhaust
New Valve Seals and Guides
Greddy Timing Belt
Skunk 2 Pro Series Cam Gears
Newly Rebuilt Distributor and Plug Wires
EFI Wizard 1000CC Injectors
AEM Fuel Rail
Marshall Fuel Pressure Gauge
Aeromotive Fuel Pressure Regulator
Edelbrock Inline Fuel Filter
Warlboro 255 Fuel Pump
Edlebrock Victor X Intake Manifold
Blox 70mm Throttle Body
EM Racing Pillar Bar and Rear Upper Strut Bar
Fluidyne Aluminum Radiator With 14 Fan
Peak Boost Turbo Kit (Tial Blow Off Valve, Tail Wastegate, 57mm Garrett Turbo, 2.5 Charge Pipes, 26 L 12 H 3 T Intercooler, S/S Dumptube, 3 S/S Downpipe ETC)
Progress Coilovers, Urethane Bushings, and Sway Bars
Omni Power Rear Control Arms
Front and Rear Adjustable Camber Kit
ASR Subframe Brace
Engine Works Battery Cut Off
Hondata S300 With AEM Boost Solenoid For Boost By Gear and AEM Wideband Gauge
Greddy Oil Pressure and Boost Gauge
Sparco Harnesses On Black RSX Seats
Skunk 2 Short Shifter
MOMO Race Steering Wheel
EBC Yellow Stuff Pads, Power Slot Rotors, -S/S Brake Lines, GSR Rear Disc Brake conversion and Front GSR Brakes.
Seibon Carbon Fiber Hood and Duckbill
15 Rota Slipstreams
i know im forgetting a bunch of stuff but yeah, oh well haha.
