Misc Parts & Tools
4" QTP electric Cutout, summit p/n QTEC40, never used. Just so buyer is aware it is listed as a 4" cutout, but the blade measures about 3 3/8" the flange is 4". $195 in Summit, sell for $150.
2.5" Stainless flex joint. New, never used. $20
Magnafuel 2 port boost referenced fuel pressure regulator. -10AN inlet, dual -8AN outlets. Used for one season, and there is nothing wrong with it. Just changing the setup. $75
Mustang AC Delete pulley. Summit P/N ASP-025030 Cost $68 new, sell for $40
NEW Moroso wheel studs Summit P/N 46180. $10
MSD Blaster 3 Coil, used for 1 summer. Summit P/N 8223 $20
NEW Bosch 1821d 5" Grinder. Have no use for a 2nd one. $70
wheel studs for a mustang?
Same thread size, but you will have to measure the knurl size needed on your current rotors. I didn’t measure this, and they did not fit. I didn’t have stock rotors though.
Not like a bimmer, you would install these through the back of your hub. Never broke a wheel stud huh?
I think he was asking if they are for a mustang not questioning wheel studs on a mustang.
More parts FS… Just changing my setup around a bit.
Custom Turbo grind Hyd. Roller cam, Spec’d by Derrick at BB&T. PM for specs if interested -$150- SOLD
Ford Hyd. roller lifters. SOLD
Trick Flow push rods $50
SCAT 4340 H beam rods 5.400" SOLD
Prof. Products 28oz Balancer -SOLD
TTT. some stuff sold.
i’ll pick up the bosch tomorrow for 50?
