Motor locking up after tranny install
jus put my rb n tranny in an now i cant manually turn engine over it locks up jus short of one revolution on the crank.engine turned over fine when they were separate…any ideas,drive shaft is not hooked up fyi
Did you check the timing belt, tensioners and timing like I said? sounds like the t belt slipped and your mashing valves
