I have a yz445 Hybrid that Im looking to either part out if I get enough interest in the parts on the quad, sell out right as a whole or trade for a stock 450 plus cash…
a little about the quad. It’s all 250R geometry. It has a PRP flip top 250r frame, Roll design +3 Long travel front end with Long travel custom axis shocks, PRP long travel swing arm with yfz450 link, rear PEP dual spring long travel big rezzy shock. The motor has a Mangura hyrdolic clutch, 445 big bore, high compression piston, stage 3 hot cam’s, decompression lever etc. Quad strictly runs on race gas and is very very fast. Everything on the quad is aftermarket and I couldnt even list all the parts if I wanted too. Never had a single problem with the quad. Always starts and has been very reliable. Only thing is, 5th gear shift fork is slipping…other then that, its a sick quad. Reason Im looking to get rid of it is because I broke my wrist a few years ago and dont really race anymore. The quad just sits in the garage and gets ridden only 3-4 times a year…
Parts list…
2003 prp yz426 chassis w/flip top subframe
250r geometry chassis setup for the yz426f motor
prp anti-vibe steering stem/clamp
tag fat bars
magura hydralic clutch assembly with carbon fiber line and carbon fiber shield at pump
pro-design kill switch
steel braided brake lines front and rear
450r spindles/calipers/braking brake rotors/hubs
atv innovations rear brake caliper
roll design lobo 2 a-arms with custom axis triple rate shocks compression/rebound adjustable
prp swingarm with yzf linkage and pep zps suspension
lonestar tapered carrier
rpm axle
lonestar anti-fade brake hub
braking brake rotor
t.m. designworks chain sliders
rear beadlocks with 18x9.5x8 turf tamers
front itp rolled 4/1 rims with 20x6x10 holeshot mx’s
ac racing 450r blackline front bumper
ac racing rear grab bar
ac racing pro-peg nerf bars
K and K Flame graphics
Denton Steering Dampner
2002 yz426f motor
fully built to 445cc by vps (vucina powersports racing)
tc racing shorty exhaust
fcr 39mm carb
yz250 kickstarter
huge aluminum radiator
fullbore radiator shrouds
fullbore fenders front/rear
clarke clear gas tank
acerbis handguards
i have some spares, like a spindle, rotors, sprokets, hydralic clutch piston assembly, springs for the shocks and spare a-arm balljoints.
I know im forgetting alot of stuff, I would hafto go over the quad personally to list everything.
If someone was going to duplicate this quad, it would cost almost 30 grand.
