My little 3 wheeler project.
So I got this old rascal scooter last year and wanted to getting it running again, instead of buying batteries I decided to throw a little gas engine instead. Well I got around to it today and here is what I did so far, I found a old mountain bike and took the front assembly off to use on the cart, it worked good only problem was the tube for the neck was a little to long so I had to chop it down.
I will also be using the bike shifter for the throttle, it works great I just need a cable for it. I also need the clutch for the engine, how do I measure the shaft, do I just use a tape measure to do it?
Only thing to do after that is cut the slot out for the chain and bolt the engine down. I also cant decide what seat to leave on there, the little one looks cooler but the big one is way more comfortable. I will add some foot pegs that extend out so im not hitting the engine.
Anyway here are a few pics of before and after.
And this is what I did today.
yea, my honda 250 i got sittin here woulda been perfect.:smiley:
↑ Was it air cooled or liquid?
will this do wheelies
and does it only have front brakes? scary…
its aircooled iirc
edit: yeah id do a disc conversion or something in the front, i bet youll be able to get this thing moving rather quickly
and def keep the regular seat, itll be better for wheelies
front tire shield so you don’t get sprayed with rocks and small road debris.
For the seat i’d say find an old banana girls bike seat. Or just come up with one completely by yourself and make it a bit safer? You could make anything really.
I do agree with originalsin about the disk brake conversion. Or come up with some kind of rear brake system as well.
is this street legal? I would lol if i saw that on the street.
air cooled of coarse.
fixed
lol, thanks dick.:smiley:
It is very back heavy with a person on it. If the engine has any torque with the centrifugal clutch on it it might be able to pop it up. If you look at the one pic with the little seat on it you can stand on the rear axle and pull up and it will do wheelies all day.
I think you should throw a wheely bar on there… for your own protection.
Be careful with that front wheel wont take much of anything to fold that over.
power brake!
this needs a very small front tire and spray
I think there’s room for another engine on the other side :wink:
