I have a small 2 1/4" aluminum bend that needs a bead rolled on each end or someone who can weld a small bead of aluminum on each end. I went to Innovative but their bead roller is broken at the moment. Let me know.
Hair spray works wonders…
search newmans e30 thread. I think there is a picture of the vice grips he made that puts a bead in pipe.
Vice grip thing was actually juicedZ4’s idea.
However that’s a little on the big side for that technique. Last I knew innovative had one.
Is like to get a bead rolled on this instead of hairspray. It’s a lower pipe and it comes off the turbo so I don’t want to chance it especially at 29psi.
I went to innovative but theirs is getting fixed
I run 27ish psi 365 days a year and hair spray works great :tup: It will hold you over till you get someone to run a bead on it.
