i need better axles or i gotta turn the boost down… pretty sure thats not gonna be an option. anyplace local make custom/hardend cv shafts?
ancas and albany unaversal,ya sure they broke due to power or just a shitty platform
universal down on broadway? Idk it broke halfway through second
wheel hop did ya in :nod
:nod but ancas is prolly better suited for a c/v setup
alright ill check them out. think your right
well it was definately a form of wheel hop, i think there was a little pot hole when the tires were spinnin, if it was on perfectly smooth road, it might not have happened.
must be because of all that beastly 14 second power going to the ground…shredding your axles clean off from the insane boost your pushing!
your cuttin some beastly 13’s too
yea
13’s are better then 14’s last time I checked!!! and I got more then enough trap to be in the 12’s and should be if I wasnt traction limited!!! I found a huge issue I had that dealt with traction issues and I fixed it…to bad the track was closed after I noticed it.
What was the issue?
Ecotec wasn’t kicking in ![]()
Supacharge dat ho!
…DOT DOT DOT…!!! EXCLAMATION POINT!!!..DOT DOT DOT…
i break axles, whats new. see if driveshaftshop.com makes them. i may or may not have purchased a set of level 2.9’s
I may or may not have purchased 5.9s… :ohnoes :ninja
those are 1850$ for the kit and they are 1000hp axles, what do you need with those? 3.9s would be plenty unless you plan on making well over 600hp.
the axles on those cars are known to break very easily with hardly any more power loaded onto them then the stock numbers
Found them cheap on htech. I didnt buy them but if i come across another deal, i am not going to pass it by
i hear that man. i need to find a solution… its 2.9’s or im gonna snatch up a set of Raxles from vortex… 2.9’s are 800, the used raxles are 600, so its almost worth it to buy the new DSS’s which are actually in my “shopping cart” at the moment. its a big decision.
