I had the same problem like a year ago. it was a Glow plug or something similar, it was blowing cold air, the gas wasnt igniting. You best call a repair man. if it continues to blow cold, shut er down.
i don’t know technical terms, but there is a rubber tube that sucks open a little vent to allow the glow plug to heat up and activate the furnace. it is probably clogged with dust/dirt. get a needle/thin screw to clean out the hose and part it plugs in to.
Is there a thermal snap disc on furnace blowers? That would keep the blower off, clearly.
Wait. I re-read the first post. The burners aren’t going on either. Never mind.
Anyways, my guess is a bad limit switch? (I don’t know if that’s the technical term on a furnace) But, that controls the cycle. That button reset that cycle or does a manual over ride. So…
I work with fireplaces. I know shit about furnaces. I’m just brainstorming.
That’s the pilot on my furnace. Sorry for the shitty quality, but iphone + flashlight isn’t the greatest.
Basically when the furnace kicks on the pilot lights and a flame hits right on the element (pencil lead looking thing sticking out across from the orange conductor).
Once that element gets hot enough it tells the furnace to kick on the main gas vents and the main burners light. Sounds like your furnace is never getting that signal. Look to see if something came loose and the pilot isn’t hitting that element anymore.
