i know this has been covered a million times and once more, but im having troubles getting my car running right. my setup at the moment is stock 370cc injectors, 264 intake and exhaust cams, hks gt2561r turbo, midmount innercooler, 3’’ exhaust and apexi power fc djetro. i have tried researching things, but to be honest i just dont understand the stuff that is explained. the car is running super rich, 10.5 on my wideband at idle and when i rev it it leans out. what i need help with is setting up the power fc just so i can drive the car to get it tuned properly. if anyone can help me out with this that would be amazing! thank you
Set your fuel correction factors for 0, and make sure you have the proper sensors selected in the options. (if it’s anything like an rb26 pfc)
is it warmed up?
it is for sr20det redtop, and yes it does the same thing all the way up to operating temp
Did you buy the PFC used?
yes
Reset the PowerFC with the commander. There is no reason (other than mechanical) it should run as you describe.
reset the ecu, idles smoothly now but still very rich. 10 on the wideband
