Im in the middle of putting the sr20 back together, but i cant seem to find the little bracket that holds the trottle cable in place, check out the pics
If anyone can help, i would appreciate it immensely
That looks like your bracket, just ground away. You could either whip out the welder and weld together a new one, which is relatively simple, because that piece isn’t terribly complicated, get one out of your KA or something and make it work, or put a big washer on each side of the nuts to pinch it on.
