i would give my left nut for that NSX
Not too often u see someone drifting an nsx
oh man. Must be the hardest car to drift. Probably similar to an MR2. Snap oversteeeer.
Those racks are EASY to build. Maybe we’ll do those too!
Incorporate it into your cage… bam.
Mid-rear cars are super easy to drift if setup properly. NSX’s and MR2’s and Boxsters.
white240 id be interested in one of those racks for my coupe wanna make me one in the new yr?
So I got my software…
First cage… learning how to use the software.
Unfortunately the tools are going to be a while before they get here
This isn’t for anything in particular… Just a practice piece.
The program also tells me where to make all my cuts and bends. Where to index the piece before the next bend is made. Coping sheets for every intersection. All measurements… Everything…
lol mark, would the cages you’d be constructing even be track legal?
Track legal?
Well… my usual practice of wood glue and popsicle sticks usually gets me past tech.
Sometimes I have to beef them up with paper mache.
Is that the answer you wanted Sean?
Do you use the edible glue? In case of a roll-over somewhere in the dark forest people get hungry you know…Something you should consider using as per material Mark.
Adam, what software are you using?
Bend Tech PRO. Bend Tech HD is in the mail.
sorry if i came off as a dick.
But, don’t you need some sortov license to fabricate roll-cages and race with them?
No. No license is required to fabricate them. My fab guy has been building cages for a long time now, and the final result will pass any racing sanction they have been designed for. Final approval would be getting tech’d at mosport. If that’s what you want your cage to be able to do, that’s not a problem at all.
Granted, the majority of caged cars are simple 4 point roll bars for street-oriented cars.
BAHAHA mark your comment about track legal made me laugh.
I got quoted 1800$ for a custom welded in 4 point cage with the cross arms here in mtl. Please someone tell me they can get it done for cheaper?
goddamn.
Everything is set, full time cage production starts Jan 1st !
Yo Marky Mark.
How much would you charge for a safety 21 style cage for a 4 door (6 point with removable doorbars). I don’t want it through the dash but wrapped around rather.
lolols
post pics of vert cage= stat
