i have a 91 nissan 240sx hutch i been putting brake fluid in and its leaking out of the rear right side, i check it and thats the only place its coming out of now is it a brake line, of is it a hose or do i need to get my brake pads? when i put my foot on the brake it goes down until i pump them what do i do?
thank you
kerry:drivin
if its leaking out your rear right side then check your rear right sides brake line maybe??? see where its exactly leaking from. you wanna look for the part where shit is leaking out and if its leaking from the brake line change the brake line then and rebleed all your brakes starting from furthest from master cylinder and work to closest. sorry if my reply is rude but you pretty much solved the problem yourself and asked again in a really vague manner.
ok thank you i wanted to be sure and not spend alot of money just fixing things that do not need to be fix!
