when i am driving i can hear a noise coming from the drivers side front tire
it sounds like something is rubbing, and does it once per tire revolution, its hard to explain the noise, but its kind of like a swooshing noise, like a ceiling fan hitting a piece of paper
it is not affected by the brakes, can hear it at all speeds
i have jacked my car up, spun the tire, but cant hear anything, i have also replaced the brakes, after i did that the noise changed in sound (higher pitch) and was quiet, but is now noisier.
looked for rubbing everywhere and i couldnt find anything at all
while i was changing my brakes i noticed that that the caliper pistons didnt need to be pushed back in as far on the side with the noise than on the passenger side, the car goes completely straight when braking though.
i looked at every little detail and i could find no marks anywhere from something rubbing
it may be the pads, but the noise doesnt change when i hit the brakes, so i figured they wernt the problem
when i spun the wheel i did notice some “ticking” noises from both sides, it sounded like the old ball bearings they used to put in roller skate wheels
well it could still be a bearing, but when the bearing is moving, it makes a different grinding/rubbing sound because the rotors are new? this could be a stretch but who know.s
Yeah I would vote for a wheel bearing, even when you put it up you might not hear it but you can feel for roughness up in the spring even or other parts around that it would transfer through…other then that if your alignment is terrible and destroying your tires…does it stop if you turn one direction or the other to change lanes or anything?
no, but i rotated my tires today, and the noise got louder (i have directional tires) so i guess the noise was coming from the back tire, and when i put it up front it got louder since it is closer to me
now, i dont recall having this noise when my snow tires were on, and it came when i got my regular tires put back on
could there be something wrong with the tire? it didnt make the noise before i put my snow tires on, could it be they messed up on the balancing? (im assuming i would get a vibration if they did)
well i figured out what the problem was, and it was the DUMBEST thing ever
there was rust on the back rotor and it was rubbing against the little metal plate that holds the brake pads in
i feel like such an idiot for it being so simple like that
me rotating the tires and messing with the brake must have moved the back rotor a bit or something which changed the noise everytime i played around with the wheels
i notice a lot more road noise now after the tire rotation though, kinda annoying
Well if just playing with the brakes and tires has moved something, you definatly want to go through and make sure every single bolt and screw is tight, and to book specs on torque, you dont want more shit going wrong whenever you drive on it now.
although i fixed the problem, there is something wrong with my back brakes… the side opposite of the piston gets almost no wear to the pads, while the other side gets about 95% of the wear
i just had to change the back brakes because i had no pad left
its a siezed caliper… one of two things… probably the first. the slides on the caliper are sticking causeing only the side with the piston to push pressure… or and i doubt it. the caliper is hanging up and staying applied after you let off.
