OK first off i am installing a bings intercooler kit, exhaust manifold, turbo outlet pipe, and doing new grounds at the same time
first how can i easily remove the front bumper on my pignose, I can’t seem to figure out an easy way to remove the screws holding in the sides. So Steps in removing the front bumper would be great.
Second whats the easiest way of installing the exhaust manifold, and turbo outlet pipe
Third any recommendations on some good grounding points
to remove the front bumper you need a 10 mil socket and wrench and a LONG extention or tiny hands, a philups screw driver and thats about it… theres 4 bolts on the top near the upper rad 2 on each side near each headlight, take out the inner fender linners and look at the bumper (light is usefull) this is where that long extention comes in handy. theres abouttttt 6 nuts you need to take off in there on each side BE CARFULL NOT TO BRAKE THEM… this is a bad thing lol then look up from the front of the bumper and youll see where the front rebar is theres 2 bolts on ither side (about where the fog lights are on the 89 or 90) there hard to miss. take those off then the plastic liner going from the bottom of the bumper to the lower rad support off and pull the bumper.
yeah they r just basic megan parts, and now that i have taken off the front bumper of my car, i want to blow the fucking thing up! I got enough broken bolts, rust and shit broken on the car to deal with for a fucking life time!
