I will be installing my oil cooler and i have a GReddy oil filter sandwich already. Can i use this to plug both lines into, or do i need the sandwich designed to go with an oil cooler? JUst wondering how the oil would flow in one direction through the lines with mine. Any other good locations to hook it up to, or is that it?
Yes you can use those lines. However i suggest a oil thermostat as oil that is to cold is worse than oil that is to hot.
Yes oil flows in one direction only and the core is more than likely ment to be used in one direction.
Ok so how do i know which points on the sandwich to plug which side into. The thermostat does sound like a good idea though.
