Seems I have an oil leak somewhere near the top of the engine. Got Canadian tire to put some dye in and take a black light to it, they say they cant see it because its behind the alternator. Are there any problem areas I should look out for? Maybe some suggestions on where to look?
well could be a simple valve cover leaking from behind the engine, I dont knwo if you have an sr or not but if you do your turbo might be leaking which can cause oil to be found in the intake manifold.
missunderstood him on the phone because of poor reception. The leak IS behind the Alternator. Now I got something to go on finally. Anymore ideas? Im about to take a good look at a diagram or something to see whats up down there.
INORIGHT?! there IS fresh oil all over the bar bushing there (sway bar?).
and thanks haha, that stupid thing was pissing me off.
is canadian tire retarded you think? what else could be causeing my alt to die all the time? there was quite a bit of oil under there before they cleaned it though
Still could have been enough to break the seal of the pan on the bottom end. Closer inspection on where the leaks are is gonna be necessary here, and how bad they are. Sounds like something has a hairline crack, wont really be able to see it, but will leak REALLY bad. Had a transmission done by mr transmission one time, looked fine, bolted it back in the car. week later, was EMPTY. they didnt tighten down ANY of the bolts, 2 had fallen out. Looks can be deceiving on your oilpan.
alright, thanks man.
Also, if it were the oil pan, it shouldnt really leak onto the strut tower and alt right? Anywho, i think I got enough of an idea to start some troubleshooting
