Oil pressure only 50psi ? max on top rpm problem
Hey guys just came from the tuning shop neetronics from oakville (note these guys are great) we stopped at 10 psi with 244whp but paul did not what to go past that because my oil pressure maxed at 50psi. paul said he would like to see 75 to 80 psi.i think 10psi per 1000 rpm… OK now how much psi (OIL) is sr20det red top supposed to max out with ,i am going to try step by step check my auto meter gauge ,wiring,pump,oil pick up,bigger pan,what ever need to fix it and need advice from you guys CHEERS
When warm at idle mine is about 50 psi, under load it varies usually tops out round 80 psi. When cold at idle obviously it’s a bit higher round 70ish psi. My sr is a black top out of a 180sx and is tuned(by Neetronics actually) to run 16 psi boost pressure. I hope this helps
When cold yes its like 65 when hot its only 50psi at 7500 rpm BAD BAD BAD
Ok did some shopping,Just bought bigger greddy oil pan ,new oil pump .and new pickup (oil strainer) I thought to my self ,if iam going to do this then do it all…lol
