Oil Pressure problem for my S14 SR
i got my S14 SR runed yesterday…but Oil Pressure is weird
idling is like 1.2 kba…but when engine rev go higher … i lost pressure… IE rev around 3200 rpm … my oil pressure is 1.0 kba… any idea for this???is it oil pump or something else…??
You wanna convert these KBA into PSI please? K. Thx.
idle is like (800rpm)16 psi … when i rev to 3200 rpm the oil pressure went down to 14 psi… i check the FSM … if rev on 3200 should b like 46~57 psi…
Idle should be 11psi+ (after car is warmed up). Mine averages 15psi.
At 3000rpm+, I am about 60psi+, which is how it should be according to the FSM.
Are you sure the gauge isn’t faulty? How does the car run? Oil level ok?
Perhaps check your oil pan or oil pump. Dunno what else it could be.
if your oil pan is fine i would suggest checking your oil press setup, did you tap it into the right location? if you did DO NOT RUN THE ENGINE anymore until you take hte pan off and check out the pickup and everything, just be very very carefull man you dont want to spin a bearing over something like this.
the oil level is ok … and i checked…there is no oil leaking … ~~
i will check the pump and oil pan …c if there is anything wrong with it… ??
does S14 SR and S13 SR use the same oil pump…or they r diffirent. ~??
today i tested my oil pressure with machenical gague …it’s working fine… ~~ ^^ … i think there is something wrong with my defi gague… ~ thanks for all the helps…
thought so. Good to hear man. Enjoy the motor. Check your meter is getting good power and ground and that its tapped to a good location. Its rare that you would get perfect oil press at idle then it would just fukc up in higher RPM.
