This is a ca18det swap performed by onijdm on my '91 s13. Engine was sourced from elsewhere.
In brief:
I was quoted $850 for the swap + $100 for Raf/Veloz 's sidemount. The final bill from onijdm came to $1750 (not including motorset), which i still paid. In return I got a car that barely moves. the exhaust wasn’t hooked up and it was going to cost another $300 to install Raf’s oem sr fuel pump, which i was told was needed. It is sputtering, misfiring and surging, bad idle and the dohc tach is bouncing all over. The knock sensor is not wired in. There are many instances of neglect but wiring appears to be the main culprit. One of the coolant heater hoses wasn’t connected and i was told that it was the seal around the butterfly valve which was causing coolant to leak. There were vacuum and hose lines running nowhere and the bov was teed directly to the wastegate. They even left a screwdriver and a fuse/bulb on the intake mani, just to show how much attention they were paying.
Inspite of all this i offered them a chance to look it over, however just for diagnosing it they wished to charge me again by the hour. After going through what i believe to be the most blatant swindle am i expected to fall for it again?
Below is a rundown of their bill:
- Swap – Including engine & wiring 10hrs $850
- Install slave, Redo ground 1hr $85
- Free seized mounts 0.5hr $42.5
- O2 housing install 1hr $85
- Intercooler + piping install 2hrs $170
- Throttle bracket 0.5hr $42.5
- Attempted clutch install 1hr $85
Labour Total $1360
Parts
Slave(50), bov(80), coolant(20) $150
IC, + piping $150
Rad Hose + IC elbow $40
Sr Intake Pipe $50
Parts Total $420
I will have to get the swap redone elsewhere now.
Hope this helps someone.
I would request the admins to not move this post for onijdm. Thank you.
