pc game help
bought a game for the pc, my pc meets all the minimum requirments, and is better or equal to all the reccommended requirments. i loaded it, when i click the icon, i get this message.
MXvsATV.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
any ideas what could be wrong?
Reinstall?
check the internet for the same error msg. it should give u a start. what game?
what game is it?? go to the install directory where you installed the game…find that file…right click it and go to compatability…click the run in combat…mode and select win98…see if that fixes it
3 times, then returned the game for a new one and same thing.
I’m guessing the game is MX vs. ATV… Something isn’t installing correctly. Do you try and run the game with the CD in the drive? It may need to use the CD to get that .exe file on there. But as mentioned before I would google it to see if it’s a common issue (possibly with your OS etc…)
game is in drive
game is in drive
this is what the error report says
AppName: mxvsatv.exe AppVer: 0.0.0.0 ModName: mxvsatv.exe
ModVer: 0.0.0.0 Offset: 00047917
http://www.mxvsatvcentral.com/forums/archive/index.php/
Is it MX vs. ATV unleashed? That’s a link to a forum, might be able to dig something up there.
