This is all for a friend, for the record. He had a crap machine about 5 or 6 years old, and took the leap to try and put together his own after buying up all the parts. He’s never done it before, total novice. Here’s the email he sent me, since I have no idea, and I know there are some people on here that know their stuff. If anyone takes the time to give me an idea to pass along i’d really appreciate it.
"I’ve gotten a really weird graphical error. It happens whenever I play something graphically intensive (ie a video game ^^). Mostly I’ve been playing WoW, so that’s where all my screen shots are from. But I’ve also gotten it in Half Life 2, and Guild Wars. It’s really bizarre, and happens on max, min, and the spectrum inbetween the two extremes. If i change a setting (or press screenshot, or minimize the game and then maximize it back), the problem goes away for a few seconds, and then comes back. In WoW i’ve noticed that if I look at the sky, I can stave off some of the problem, but not fully. I was playing WoW in windowed mode for awhile and that helped. But now it happens in both. And I’ve also noticed that if I spend a bunch of time inside a building, it seems that I don’t get the problem. If I am outside or leave the building too soon, I get the problem. A lot of times I’ll have the problem, then go to an instance (an indoor setting), and then not have the problem for the rest of the time I’m on. Also it doesn’t always seem to do it at a certain point. Sometimes I’ll boot up my machine, log in, and play with no problems, othertimes it’s there as soon as I log in. Conversely, I can play for 4 hours with no problem, leave my machine on overnight, log in and have problems, or I could not have them.
The problem gets really bad, and then my whole screen freezes, and goes into suspend mode, where the only way to fix it seems to be to manually reboot it. Then it’s a crap shoot whether or not my 36 GB drive with my OS on it will be recognized or not. Or windows will load, but my mouse (optical intellimouse by microsoft plugged in via USB port, and to fix it i will have to restart the machine, and normally get the “error loading OS” message again.
Any thoughts would be appreciated.
Machine:
Running Windows XP Pro and encased in a ThermalTake Tsunami Series Aluminum ATX Mid-Tower.
Mobo:
Asus A8V Deluxe VIA Socket 939 ATX Motherboard / AGP 4X/8X / Audio / Gigabit LAN / Serial ATA / RAID / USB 2.0 / Firewire (A455-2110)
CPU:
AMD Athlon 64 3800+ / 512MB Cache / 2000 MHz FSB / Socket 939 / Processor with Fan (CP1-A64-3800)
CPU cooling:
Thermaltake A1838 Silent Boost / Socket 754/940 / AMD Opteron/Athlon 64 / Ball Bearing / Copper Core / CPU Cooling Fan (T925-1066)
RAM:
Ultra 1024MB PC3200 DDR 400MHz Memory (ULT31664)
GPU:
BFG Geforce 6600 GT OC
PSU:
400W ATX power supply from comp usa (had a problem with my ultra x-connect, and i just needed something to see if it would fix it)
Hard Drives:
Western Digital 10k rpm, 36.4 GB SATA raptor drive (windows is installed here, sometimes during a hard reboot it, the computer seems to forget that the drive is here and it pops up with “Error detecting OS”)
Western Digital 7.6k rpm, 80 IDE drive
Optical Drive:
IDE dvd drive from my old machine because I couldn’t get the dvd-rw [Plextor PX-712SA / 12x4x16x DVD+RW / 8x4x16x DVD-RW / 48x24x48x CD-RW / Black / Roxio Software / White Box DVD Burner] to be recognized, though I’d still rather have the Plextor in my new machine if possible…
And a floppy drive."
