alrite i need a diagram or something telling me which wires from the car stereo harness in the car are which…all i see are these stupid wires with stripes and dots, why cant it be one simple color?
i need to know which wire does what to hook up this harness inside the dash… its a 90 240sx fastback
all these viewers, no answers, or can somebody just come wire this directly for me for a small fee?
ok dude, you have to options, Like my car i have hard wired everything, As in factory harness cut out and then the loose wires in the car wired to the wires off of my deck. Of you other option is to go and for $15 get a reverse harness. this will put the stock radio plug back in your car. If you want more infor pm me.
This might help.
Edited with a new question… sorry :lol:
Run the amp remote wires from the same source, all they are is a signal to tell the amp to turn on… Just wire it to the same wire that turns on the
stock amps in the 240. I think it is the plain blue wire comming out from the deck harness.
If your harness is the same as mine, which i think it is(you have a 90, mine’s an 89), You shouldn’t have two blue/white wires, you should have one blue/white and one blue/yellow.
