Group Buy price $2050.00
Why a Dana S60?
Bolt-in to a 3d/4th gen F-bod
Stronger than a 12-bolt or a 9"; ring gear sizes- 12-bolt=8.875", 9"=9"duh, S60=9.75" the S60 standard gears are good for 1200 rear wheel HP!
True trac or Power-lock standard
35 spline axles
Chrome Cover
3 or 4 channel ABS
gear ratios - 3.54, 3.73, 4.10, 4.30
weight w/brakes—12-bolt=190 lbs, 9"=205 lbs, S60=215 lbs.
Dyno Tested! your rearend will be run on a dyno to break it in, you will get it ready to run!
Brakes: The 93-97 brake caliper brackets are included, if you have LS1 brakes, Strange wants your backing plates sent to them before your rear is built.
ABS: 3-channel setup is built in, 4-channel will need your reluctor rings. There are 3 ways of doing this; send in your axles to have them pressed off, buy new reluctor rings for $70, or we can press the off your axles.
Spool: several spools are available, price will be less than a posi, let us know what your needs are.
Shipping: To save on shipping, we will have them all shipped to PM Performance. You can pick up here, or have it installed here. Depending on how many are ordered we should be able to hold shipping to $150.00 max, maybe less.
We are also looking into installing the backing plates/reluctor rings here after the rearends arrive.
Strange Dana S60 $2050.00
Driveshaft: you will need to shorten your driveshaft 1 5/8" from stock, or just buy a new one. If you are buying this then a stock driveshaft WILL be your weakest link. Strange offers driveshafts as well
Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints, Strange Heavy Duty Yoke(primarily street use) $210
Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints, Forged Strange Yoke(Street/Strip Use) $290
Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints, Strange Ultra Solid U-joints (Serious Drage Racing)$330
This Group Buy will need a min of 5 rearends ordered for these prices to be valid, and we are looking to place the order on Monday, March 5th. Since Strange builds each rear as a custom piece,(no off-the-shelf units)it takes about 4 weeks from the order date to get it in. This way, we can get the rearends in the first week of april.
Payment: Since Strange will be building each rear custom, Payment will be needed when ordered. We will cover shipping until they arrive.
