My dads 95 exploder is having brake issues. The pedal goes to the floor. there are no leaks and the master cylinder was replaced. We bled the brakes for a good hour tonight and the brakes hold pressure as long as the car is off(no pedal fade at all), but when you start the car, the pedal goes to the floor with very little pressure. WTF is wrong?
the only thing I can come up with is the vacumn booster or something is funky.
I never bench bleed. But I’m very farmiliar with workin on cars. If you did in fact get all the air out, then you probably bought an Advanced Auto part. Return it, and never deal with them again.
and I have no idea how you get away with not bench bleeding master cylinders. I always do and sometimes you dont even have to bleed the system… b/c im that good :eek: :steelers:
