Power Locks/ Power Windows
I was wondering what you need to make the base model 240sx have p/l, p/w?
Or if its not work the work or money
Get 2 doors off a loaded 240 and start figuring out the wiring. There are only about 8 wires that you have to figure out so it shouldnt be too hard.
I have all the wiring… with easy access to it as well on my parts car. You’re more than welcome to it when it gets a bit warmer (It’s kinda covered in snow) :E
could i also put power mirrors in as well ?
I would still keep my door i would change everything out with the power parts right?
Could you PM me how much you want for all the parts nessesary
You can have all the wiring you want if you take it out yourself!
Everything is possible depending on how much time you want to spend on it. And yes you can keep your door and just transfer evrything over.
Thanks for the help and i will PM you if i end up buying the car without p/l,p/w which i probaly will
