The car is a 97 neon, just recently replaced the radiator and temp sensor. Everything worked perfect up until tonight. So i get home and shut the car off but the fan doesnt shut off. So i leave it alone and come back out in 5 or so minutes and its still on. I dont think its supposed to run after the car is off, but not 100% sure. As a temp fix i just pulled the rad fuse until i need to go somewhere.
Thanks,
pretty sure the neons have a fan module that likes to corrode and cause issues like this.
ok thanks, that gives me something to look more into
my girlfriends 2000 cavy did this as well
How is your fan even going on? Mine hasnt even gotten close to needing the fan to go on
not sure man
You figure this out yet?
Give me a call if you need help.
Radiator fan control relay circuit problem, im gonna change it tommorrow
Hey where is it and where did you get a new one? Pretty sure mine is going bad too.
Just under the battery on the frame rail, its black and silver. I went to M&M and got one…
