I’ve noticed quite a rattle coming from the driver side front suspension when I hit shitty roads.
It sounds like the top hat bolts are loose, but that’s not the case.
I have H&R springs on the car, but they’ve been on for like 6 months and I am just hearing the noise now. Any thoughts on what it could be?
check that you didn’t bend a swaybar endlink - could be bent up and its making the swaybar contact something. happened on my sti… i imagine the wrx endlinks are equally as crappy
That’s true, we will. (I work there) I can tell you it’s likely the swaybar bushings, check those first. Or just replace them, they are very easy to replace. But if you bring it to us modded we’ll tell you to take a hike. Warranty time makes it not worth our time.
