hey guys i know most tires have alphabetical speed ratings, some tires are rated faster than others. some people say that going beyond the rated speeds can cause a tire to blow out, early blowouts a usually caused by tire damage, under/over inflation, improper balancing, but if the tire is properly maintained, would it really blow out from going too fast ? have ANY of you EVER had it happen to YOU ? on good tires, just going above the speed rating, im not talking about shit worn tires that you picked up from the yard, but tires you purchased within a season or two, have one ever blown out for anyone from going too fast ? was it properly inflated/maintained and never repaired ? alot of people seem to be speeding on underrated tires, let me know what you guys speed,
please refrain from ‘slow down’ comments, i am not acusing anyone (inlucding myself) of going too fast. this can also be applied for track driving on non-racing tires and going too fast
Buy good, suitable, tires. Install correctly and keep inflated correctly. The speed ratings are based on what the tire can do for more than 12 straight hours IIRC.
the tires are engineered to blow up at like 1000% of their rating.
but it’s for a reason.
it’s not just about the maximum speed in a straight line, they also take into account hard braking from that maximum speed (which will also load the front tires with way more weight) and sidewall construction, heat dissipation, things like that.
It’s not so much about the blow up but what is considered a ‘safe’ level of performance.
