H vs. T Speed Ratings
Can someone help fill me in on speed ratings for tires and how much it matters for a daily driver.
I need to buy new tires for my car, Cadillac CTS, the factory recommends H rated tires. Do I need to go with H rated tires or can I go with T rated ones? Dunn Tire says they will do it, but don’t necessarily advise doing it, but couldn’t give me a reason other than, “because it’s what the factory recommends and your ride won’t be as nice.”
I’m not concerned about the cost of the 2 different tires I’m looking at, as it’s only about $40. My concern is that the video reviews on the T rated tire (Continental TrueContact) were excellent in snow and wet surfaces and was rated top in the group among both H and T rated tires they were compared against. The H rated tire (Continental PureContact) was still good, but they didn’t fair as well in their respective group.
What am I going to lose by going down a level in rating?
Videos if you care:
PureContact: http://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=PureContact+with+EcoPlus+Technology&partnum=355HR7PUREC&vehicleSearch=false&fromCompare1=yes#testResults
TrueContact: http://www.tirerack.com/tires/tests/videoDisplay.jsp?ttid=189&videoID=303
It’s just a speed rating, so you’ll lose some safe max speed. It’ll still be safe to 100mph though.
Top speed is part of it, but there is also sidewall stiffness and a few other specs that go into the rating.
Yeah on paper he might lose some cornering ability but at the H & T level of speed rating I’m not sure he’ll notice it. Especially on a daily driver.
It is a speed rating, not a sidewall stiffness or cornering ability rating:
http://www.nhtsa.gov/cars/rules/rulings/UpgradeTire/Econ/TireUpgradeII.html
Yeah you’re right, I guess I was thinking load rating?
They were all concerned about putting on tires less than the recommended speed rating, but the load rating is actually 1 more (99 vs 98) on the new tires vs stock.
Load rating is not an indication of sidewall stiffness or cornering ability.
For example a Dunlop Direzza ZII is load rated 91, has great dry cornering ability and subjectively speaking has a stiff sidewall.
I would assume the Dunlop Winter Maxx with a higher 94 load rating does not have the same cornering abilities.
http://www.tirerack.com/tires/TireSearchResults.jsp?width=225%2F&ratio=45&diameter=17&rearWidth=255%2F&rearRatio=40&rearDiameter=17&zip-code=
Here are 3 Dunlops (Z102, ZII, SP Sport Signature) that are all load rated 92, but I am sure they have different sidewall stiffness and cornering abilities:
http://www.tirerack.com/tires/TireSearchResults.jsp?width=225%2F&ratio=50&diameter=16&rearWidth=255%2F&rearRatio=40&rearDiameter=17&zip-code=
Those aren’t direct links, you’ll have to filter by brand.
Usually manufactures will set their top speed governor based on the speed rating of the tire, which is the reason they’ll list a minimum speed rating for the replacement tires. If you’re not planning on exceeding 118mph for extended periods of time the T rated replacement will be fine.
If GM put T rated tires on it from the factory they would have to set the governor at 118 or under though, and when people reading car review see “governor limited 118” on a luxury car they would assume it’s garbage compared to the other vehicles in it’s class that were limited to 130 or 150.
That makes sense. Wish the dummies at the tire shop could explain it like this.
I’m sure they’re not allowed to. If they let you put T rated tires on your H rated car then you go blow a tire at 125mph your family will sue the tire place, and sadly they’ll likely win.
I remember going through this with BMW. The car is limited to 160 but the tires from the OEM factory are Z rated and they wouldn’t downgrade them since the OEM safety requires them even if the tires are rated faster than the car goes.
