carbed 350 anyone know the rough output of the fan that’s on there so i make sure i flow enough cfm for this thing. also looking for a dual core full size rad without tranny lines if anyones got one cheap.
:fart:
use a LT1 or LS1 electric fan setup. its more then enough CFM for that motor of yours
do they use dual core rads?
i think they use a 3 core aluminum rad or a 2 core.
you can get a cheap summit universal rad that will work for cheap or get a rad out of a newer S10 thats aluminum and strap an LT1/LS1 efan on it and it should be more then enough to cool
brian has radiators and fans out the ass.
brian how much for the fan/shroud setup and a rad outa an ls1
PM him for price
this is what i have, and it works real good.
i have installed them in the truck, the stang, chads stang, todds chevelle, todds monte and brians old race truck. not one ride has an issue with over heating. also those fans teamed up with a Flexalite fan controller works very well together. the controller is around 80 bucks from summit
already waiting on him to respond to 1 pm
pmreturned
